  New Posts New Posts RSS Feed - Looking for an 8.8
Looking for an 8.8
trevordavis0521 View Drop Down
Newbie
Newbie
Post Options Post Options   Thanks (0) Thanks(0)   Quote trevordavis0521 Quote  Post ReplyReply Direct Link To This Post Topic: Looking for an 8.8
    Posted: 23 October 2019 at 9:15am
Looking for an explorer 8.8. Swapping into a tj. If it has 3.73-4.56 that would be ideal, but if it doesn’t I will still consider it for the right price.
Sorry, meant to post in “Wanted” discussion area.
*8.8 has been found*
Edited by trevordavis0521 - 24 October 2019 at 4:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 98TJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2019 at 9:25am
Newbie
Newbie
Post Options Post Options   Thanks (0) Thanks(0)   Quote trevordavis0521 Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2019 at 11:05am
I am heading over to LKQ in an hour...just trying to see if anyone had one laying around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83K10 Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2019 at 2:33pm
Make sure you get a 1995 or later for the disc brakes. Also the u joint to flange adapter is a 1330. Grab it off the driveshaft if you want 1330.  Your yj should have 1310 joints unless it has been upgraded. You can get a 1310 to 1330 spicer adapter joint. Give me a shout if you need the part number. I have some sitting on the shelf. They also make a flange adapter that is 1310. I think the part number is 2-2-1379 on for the 1310 version.
Newbie
Newbie
Post Options Post Options   Thanks (0) Thanks(0)   Quote trevordavis0521 Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2019 at 9:21pm
I’ve already 8.8 swapped my yj a few years ago. I’ve built a few 8.8’s since then. This one is going in the gf’s tj. LKQ had 3 explorers/ mountaineers, all the rear ends were gone. Called up Karla down at complete auto recyclers and she had one from a 97 with 3.73 and lsd. The front LP d30 is already 3.73 and since it’s a daily the lsd will work just fine.
Newbie
Newbie
Post Options Post Options   Thanks (0) Thanks(0)   Quote trevordavis0521 Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2019 at 9:23pm
*AN 8.8 HAS BEEN ACQUIRED*
This page was generated in 0.029 seconds.
