Forum Home Forum Home > Classified Ads > Wanted!
  New Posts New Posts RSS Feed - 86 4Runner Sun Roof Glass
Toydawg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toydawg Quote  Post ReplyReply Direct Link To This Post Topic: 86 4Runner Sun Roof Glass
    Posted: 26 July 2021 at 11:28am
I lost the sunroof in my 86 4Runner when I trailered it to MS a couple of weeks ago. Literally just blew out, I had no windows open or anything, apparently the air passing over the top just sucked it right off the truck. Anybody know where I could find one, or a suitable replacement that will fill up the hole in the roof? Did I mention that I HATE sunroofs? Thanks
1984 Toyota pickup, locked 5.29s, dual cases, Longfields, 22R with low range cam and header.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 98TJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 July 2021 at 11:41am
bpr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bpr Quote  Post ReplyReply Direct Link To This Post Posted: 26 July 2021 at 12:23pm
another option is fab a piece and weld it in
2018 JL Rubicon Stock
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83K10 Quote  Post ReplyReply Direct Link To This Post Posted: 26 July 2021 at 5:49pm
Good luck. I've been casually looking for one for several years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toydawg Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2021 at 10:38am
I thought so, was hoping you had found a solution. I saw the $600 one on eBay, really don't want to spend that kind of money on a piece of glass. I like the 'weld it up' idea, but my bud who could do that and make it look factory is no longer with us. Might try a piece of Lexan...
Post Options Post Options   Thanks (0) Thanks(0)   Quote alabamatoy Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2021 at 2:23pm
You need to sell me the 4Runner.  This will solve your problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83K10 Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2021 at 3:33pm
Maybe I should just start machining them out of lexan. I need to look close at mine. I can't remember if they are curved or not. I bet there's quite a bit of demand for them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 98TJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2021 at 4:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 98TJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2021 at 4:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toydawg Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2021 at 6:09pm
It's in MS now. Had I known it was going to shed its Sun Roof at Cullman you might have had an opportunity for purchase...
Edited by Toydawg - 28 July 2021 at 6:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83K10 Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2021 at 9:45pm
I have a blodgett commercial oven that should be large enough to heat them. Hrm....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toydawg Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2021 at 6:50am
I volunteer to provide a test bed for your prototype efforts.Big smile
bpr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bpr Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2021 at 10:26am
if you don't care if it ever opens or it looks factory: cut lexan to fit, use brackets or stops on underside and then fiberglass the top.  Shouldn't leak and you could finish and paint top side edges to make it look ok.  You would still have light through lexan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toydawg Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2021 at 7:55am
I like this idea, but I don't look forward to the fiberglass piece. I have very limited experience with fiberglass, and the people I know who have used it said it is a pain to work with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alabamatoy Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2021 at 8:24am
I have already made one trip w/ the trailer to Vicksburg this year, another one to get a 4Runner is not intimidating.
This page was generated in 0.041 seconds.
