  New Posts New Posts RSS Feed - Wife Replacement
Wife Replacement
Post Options Post Options   Thanks (0) Thanks(0)   Quote 98TJ Quote  Post ReplyReply Direct Link To This Post Topic: Wife Replacement
    Posted: 06 March 2022 at 10:07am
bpr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bpr Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2022 at 8:18am
LOL, I needed a good laugh this morning.  LOL
2018 JL Rubicon Stock
Post Options Post Options   Thanks (0) Thanks(0)   Quote alabamatoy Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2022 at 1:37pm
Tha wins the "insanely complicated solution to a simple problem" award.  Get (or make) a pressure bleeder, far simpler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 98TJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2022 at 1:49pm
When I had to replace the front calipers on our 2006 F350 in a campground after burning them up coming some big mountain pass in Colorado, a pressure bleeder was the only thing I could get to work.  Tried vacuum bleeding and pumping the pedal, neither worked for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alabamatoy Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2022 at 6:10am
Originally posted by 98TJ 98TJ wrote:
When I had to replace the front calipers on our 2006 F350 in a campground.......
I remember that.  Seems to me like it was in Nathrop, Chalk Creek Campground (I had to look up the name, my memory for such is no good).  I have never had any luck with the vacuum bleeders.
On Ashley's BFs 06 BMW, you had to have a PC hooked up to the car and special software to run the ABS pump in order to bleed the brakes.  Pedal bleeding them simply was not an option: by the time you spun the pump and tried to pedal/bleed, the ABS cycle was done, start over again.  With the pressure bleeder you could run the correct ABS routine (for whichever wheel) and crack open the bleeder without running out of time.  Without the PC/app running the pump, you simply got nothing out of the bleeder!
This page was generated in 0.035 seconds.
