  New Posts New Posts RSS Feed - Offroad jack option vs hi lift
gumataotaom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gumataotaom Quote  Post ReplyReply Direct Link To This Post Topic: Offroad jack option vs hi lift
    Posted: 25 August 2024 at 8:23am
I purchased one of these for my toyota.  Haven't trail tested (pavement princess and DD) but did test in my garage.  It is very similar to the safe jack I have for my jeep but for a fraction of the price with all of the various extensions (most of which I won't use given my vehicle height but neither would I use all the ones included with my safe jack for the jeep) and a much better base plate add on than the safe jack one.
I got mine on zorro with a discount code but if u did a search on the jack I found some for even less. So between $114 and 153, this is hundreds cheaper than the safe jack (if u got the fully loaded option i.e the general) and IMHO, maybe a little safer/stable than the hi lift.  Definitely a smaller footprint and it all fit in the toyota cubby under the seat where the stock jack mounts (new jack fit perfectly when I replaced the toyota jack using the same cradle).  Comes with it's own bag for those that have jeeps to toss in the back.
Something to consider if you're like me and was tired of looking at my hi lift mounted to my hood rusting away adding more weight to my rig.  Of course it isn't as versatile as a high lift if u needed to use it as a come along on the trail but for its primary purpose to jack up your rig to swap a tire it should work just fine.
Jeep (not schoolbus) with scrapes underneath from following Toyotas
stout22 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stout22 Quote  Post ReplyReply Direct Link To This Post Posted: 27 August 2024 at 7:54am
It looks like a good solution, but I wish it had at least one more extension for the handle
stout22
76 Bronco
302, EFI, C4 Auto, 4.3 Atlas, 3-link/4-link and Super Duty D60 and Sterling w/ Grizzly lockers, 40" Cooper SSTs
Post Options Post Options   Thanks (0) Thanks(0)   Quote gumataotaom Quote  Post ReplyReply Direct Link To This Post Posted: 27 August 2024 at 2:34pm
I looked at the new style offroad floor Jack's w the oversized wheels but I wanted something w a smaller footprint
Post Options Post Options   Thanks (0) Thanks(0)   Quote alabamatoy Quote  Post ReplyReply Direct Link To This Post Posted: 29 August 2024 at 1:07pm
Bottle jack and some wooden blocks.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote gumataotaom Quote  Post ReplyReply Direct Link To This Post Posted: 29 August 2024 at 3:43pm
Doc
You may keep wooden blocks in the 4runner but that isn't part of my basic load plan :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote alabamatoy Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2024 at 2:31pm
Originally posted by gumataotaom gumataotaom wrote:
Doc
Bad idea.  I have had multiple situations where the jack was sinking into the ground, and some pieces of 2X12 spread it so it doesnt sink.  Also makes a short jack reach much higher, so multiple purposes.  Some cribbing is always a good idea to have around, to block something up.
This page was generated in 0.033 seconds.
